2006 Scion tC, Door Lock, Remote Starter, Bypass
thebull369
Member - Posts: 11
Posted: December 13, 2016 at 10:12 PM / IP Logged Link to Post Post Reply Quote thebull369
Hello all... I am trying to wrap up a remote car starter install for a Scion tC (Automatic). The one thing I do not have working on the remote starter is the door locks. I have read on several posts and install sites the following wiring spec for the Lock and Unlock:
Power Lock      green to blue      -      driver kick, 20 pin plug, pin 15
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock      purple to pink (double pulse)      -      driver kick, 20 pin plug, pin 14
The issue I have is I cant find these wires anywhere in the Driver side kick panel. Does anyone have a picture or something of where these connectors are located?
Appreciate the help in advance.
thebull369
Member - Posts: 11
Posted: December 13, 2016 at 10:23 PM / IP Logged Link to Post Post Reply Quote thebull369
Hello,
I am installing a XK05 PKTI Bypass Module with my Python 4103P. I am using the wire to wire method versus the D2D method to hook this up. The issue I am having is I cannot get the XK05 to be programmed. I have the device where the red light is on, I put the key in to the ignition and the XK05 never flashes or does anything. To my knowledge I have hooked up everything correctly. Anyone have any ideas on what might be going on?
Thanks in advance.
thebull369
Member - Posts: 11
Posted: December 14, 2016 at 2:08 PM / IP Logged Link to Post Post Reply Quote thebull369
I have the bypass issue working now (needed a new bypass module). Just need to figure out the door wiring... ANyone have any ideas?
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
