XK05 Issues, 2010 Ford Taurus
97f150ext
Copper - Posts: 104
Posted: January 09, 2017 at 11:00 AM / IP Logged Link to Post Post Reply Quote 97f150ext
2010 Ford Taurus, standard key ignition. Installing Avital 4103 with an XK05.
XK05 was flashed to latest version.
Installed, programmed and remote start worked great. 30 minutes later the remote start would not work, nor would the car start with either of the ignition keys. I removed the main harness from the XK05, and the car would then start with either ignition key.
Reprogrammed XK05 from directechs, programmed to car, and same sequence occurred.
Car was not locked with the door open or with the factory keyless during any of these tests.
I concluded that the bypass module was defective, given the vehicle would not start with the keys.
I ordered a DBALL2 to replace the XK05, but wanted to know if anyone has had a similar experience with bypass modules failing shorter after installation. I have had similar issues, but not with the Ford firmware.
dskemaite
Member - Posts: 25
Posted: January 13, 2017 at 10:54 AM / IP Logged Link to Post Post Reply Quote dskemaite
how u wired up the xk05 d2d or w to w
eddddddddddddiiiiiiiiiieeeeeeeeeeeee
97f150ext
Copper - Posts: 104
Posted: January 13, 2017 at 12:39 PM / IP Logged Link to Post Post Reply Quote 97f150ext
The XK05 was wired D2D.
I swapped out the bypass with a DBALL2 and all is well.
My conclusion was the XK05 was defective.
dskemaite
Member - Posts: 25
Posted: January 14, 2017 at 8:54 AM / IP Logged Link to Post Post Reply Quote dskemaite
good
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
