Viper 5701 starter/ignition relay connections
nomaxtech
Member - Posts: 10
Posted: February 04, 2017 at 9:52 PM / IP Logged Link to Post Post Reply Quote nomaxtech
My question is not vehicle specific. I'm installing a Viper 5701 alarm & remote starter in my 2012 Honda CRV. The Quick Reference Install Guide lists out the purposes of the wires on the Heavy Gauge Relay Satellite harness as
  • H/1 - PURPLE Starter output to starter
  • H/2 - GREEN Starter input from ignition
  • H/3 - RED (+) 30A High current 12v input
  • H/4 - ORANGE Output to accessory circuit
  • H/5 - RED (+) 30A High current 12v input
  • H/6 - PINK Output to primary ignition circuit
  • H/7 - RED / WHITE (+) 30A High current 12v input
  • H/8 - PINK/WHITE Output to 2nd ignition
So, why are there 3 different 30A High current inputs? Do I have to use them all? Do I tie them all into the same constant 12v wire from the ignition harness? Why are 2 RED and one RED / WHITE?
Please help so I can get this vehicle back together before Monday!
smokeman1
Platinum - Posts: 1,589
Posted: February 05, 2017 at 3:54 PM / IP Logged Link to Post Post Reply Quote smokeman1
Yes for the listed vehicle you would need all three connected to a 12 volt constant source.
RED / White is the 12 input for Ignition 2 circuit
Red is the 12 volt input for Ignition 1
RED / Black is the 12 volt input for the Accessory/Starter
These three are inputs for the outputs for the Pink, Pink/White, Orange, and Violet wires
nomaxtech
Member - Posts: 10
Posted: February 05, 2017 at 4:31 PM / IP Logged Link to Post Post Reply Quote nomaxtech
Thank you! That is what I assumed but wasn't sure.
There is no RED / BLACK, just two solid REDs, so other than pairing them with the outputs they are adjacent to, there is no differentiating them.
What do I lose if I connect both of my car's accessory 1 and accessory 2 wires to a single output? Is there any reason to not do this? I realize this could sound like a dumb question but I really do want to know the answer.
Thanks!
Platinum - Posts: 7,828
Posted: February 05, 2017 at 5:06 PM / IP Logged Link to Post Post Reply Quote kreg357
It is best to keep those two circuits isolated, just like the Honda design team wanted. Not sure of the exact combined load of those two
Accessory circuits, but it might exceed the Vipers Orange ACC1 output.
The Viper has a Pink/White Flex relay output that can be programmed to Accessory. Use that wire to power the cars ACC2 wire.
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
