2012 Equinox RSR issue
cneubert42
Member - Posts: 46
Posted: August 04, 2017 at 2:34 PM / IP Logged Link to Post Post Reply Quote cneubert42
Looking at a vehicle that someone else did the install on, 2012 Chevy Equinox, DBall 2 with T harness, smart start module. basically the RS works as it should (3X lock press on factory fob) however the fob goes dead after start. I know this is more of a vehicle issue as the fob doesn't work as soon as the keysense wire sees it in the switch. Just curious if there is a TSB or workaround that anyone has discovered, or should I just suggest an RF kit for the DBall2 and call it a day? Any help is much appreciated. Also I don't believe the smart start is activated and I can't do it myself so I can't say anything for that working or not.
sparkie
Platinum - Posts: 2,061
Posted: August 04, 2017 at 5:02 PM / IP Logged Link to Post Post Reply Quote sparkie
The factory remote not working when the ignition is ON is normal unless the vehicle has a GM remote starter. You would have to install a RF kit to get around this issue. The DB-ALL2 must be programmed though to work with a RF kit. If the install was done some time ago the installation may also need revised to reflect the updated firmware. There were issues with the original few versions.
sparky
Saturday, November 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
