2016 nissan rogue interlock installation
tserigne
Posted: August 07, 2017 at 4:44 PM / IP Logged Link to Post Post Reply Quote tserigne
Need wiring for interlock device, just starter kill, 12 volt constant, and ignition +
thanks
car nut
wirewise
Moderator - Posts: 489
Posted: August 07, 2017 at 4:56 PM / IP Logged Link to Post Post Reply Quote wirewise
This is without smart key: https://www.the12volt.com/installbay/downloads.asp?srch=all&term=rogue
If it has smart key, the wiring may or may not be the same. You'll have to check.
~wirewise~
tserigne
Posted: August 07, 2017 at 5:07 PM / IP Logged Link to Post Post Reply Quote tserigne
i need a + starter wire, im thinking under the hood from starter relay. Its common that i have to run wires to starter relay underhood.
car nut
Platinum - Posts: 13,725
Posted: August 07, 2017 at 5:56 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Have you located the starter relay under the hood? Do you have a volt meter?
Posted: September 02, 2017 at 1:41 AM / IP Logged Link to Post Post Reply Quote howie ll
Why do you need a + starter wire? Polarity doesn't matter to the a starter kill internal relay switch connections providing it's supplied with ignition (+) and ground.
Posted: September 04, 2017 at 1:11 PM / IP Logged Link to Post Post Reply Quote i am an idiot
I am pretty sure his interlock comes with a prewired socket for the starter kill relay. You will have to discard the socket and wire the relay as follows. 95 goes to the wire of the interlock that disables the starter. 85 connects to ignition. Cut the negative starter wire and connect one end of that to 30. The other cut wire connects to 87a
