Compustar CM6200 Wont Go Into Reservation Mode
icarus_icarus
Copper - Posts: 229
Posted: August 08, 2017 at 12:23 AM / IP Logged Link to Post Post Reply Quote icarus_icarus
My CM6200 on my 04 Jeep TJ manual has been working perfectly fine until about two months ago now.
Now when I try to put it in reservation mode, when I open and close the door part, it immediately shuts off when the door is closed and doesn't go into reservation mode (or lock the doors which it used to do.) Once in a while it works fine, most of the time it doesn't now...
Any ideas?
·Ď˘ĺrµ§·
Compustar CM6200 Wont Go Into Reservation Mode - Last Post -- posted image.
icarus_icarus
Copper - Posts: 229
Posted: November 10, 2018 at 10:56 PM / IP Logged Link to Post Post Reply Quote icarus_icarus
Still doing this on and off randomly. I've gone through the wiring and it all looks good. Not sure what it could be...
·Ď˘ĺrµ§·
lurch228
Silver - Posts: 1,338
Posted: November 11, 2018 at 4:51 AM / IP Logged Link to Post Post Reply Quote lurch228
Try checking the factory door switch clean or replace if working intermittently. If the door switch is not making a good connection and the R/S see more than a single connection instance it will think the door was open closed and reopened and cancel the reservation mode.
icarus_icarus
Copper - Posts: 229
Posted: November 11, 2018 at 4:53 AM / IP Logged Link to Post Post Reply Quote icarus_icarus
I did check them when I went over the wiring. It also does shut down immediately when the door is closed when it does malfunction.
·Ď˘ĺrµ§·
lurch228
Posted: November 11, 2018 at 5:05 AM / IP Logged Link to Post Post Reply Quote lurch228
So when the door switch is tested with a DMM and you wiggle the switch there is no variation in the reading. The R/S will think the door was opened closed and opened even if its only for 10ms which would only look like a slight flicker to the eye.
icarus_icarus
Copper - Posts: 229
Posted: November 11, 2018 at 5:07 AM / IP Logged Link to Post Post Reply Quote icarus_icarus
I didn't notice any, but will check them again. I had to press them in about 2mm before they even registered...
·Ď˘ĺrµ§·
lurch228
Posted: November 11, 2018 at 5:39 AM / IP Logged Link to Post Post Reply Quote lurch228
With you system there are four monitored inputs for the reservation mode.
!. Footbrake
2. Parking brake
3. Hood pin
4. Door pin(s)
Any one of the switches or the wiring to them needs to be verified to have solid connections and proper function.
Otherwise try unplugging the brain from both power and ground and then connect the units power and ground together to drain any residual power for 5 minutes.
If problem persists likely unit has gone bad.
iskidoo
Silver - Posts: 1,046
Posted: November 11, 2018 at 7:01 PM / IP Logged Link to Post Post Reply Quote iskidoo
If the door switch is the same on driver and passenger side, try swapping them. Should tell you wether it’s the driver switch that’s an issue or not.
Steve G
Tuesday, November 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
