Open With Momentary, Stay Latched Until Reset
spartanfan
Posted: August 24, 2017 at 5:18 PM / IP Logged Link to Post Post Reply Quote spartanfan
Here's what I'm trying to accomplish...
With engine on/running:
Upon switch activation, accessory will power up +12vdc with constant power;
When door opens, ground momentary, Relay will open accessory circuit and stay latched open to kill accessory (Keep in mind +12vdc is still constant...but not flowing to the accessory any longer);
Latch will reset (close) when the constant +12vdc is removed.
Any help is greatly appreciated! Thanks!
the12volt
Administrator - Posts: 3,957
Posted: August 24, 2017 at 8:56 PM / IP Logged Link to Post Post Reply Quote the12volt
If I understood your description above correctly, this should work.
Open With Momentary, Stay Latched Until Reset - Last Post -- posted image.
Open With Momentary, Stay Latched Until Reset - Last Post -- posted image. the12volt • Support the12volt.com
Wednesday, December 3, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
