Viper 5806V Remote Start Issue
jdigitty88
Posted: October 23, 2017 at 10:03 PM / IP Logged Link to Post Post Reply Quote jdigitty88
HI,
First of thanks to the site, I jumped in to my first alarm/ remote start install.
I have most it figured out except the remote start:
Symptoms:
Try to use R/S it flashes one time and you can here the brain clicking but doesn't do anything (crank)it tries again before failing. I checked for voltage on the starter output side of the brain and nothing. It does start with key like normal. Also when i try R/S it also doesn't give the ignition power as the fuel pump doesn't prime.
Wiring:
Red/Black- n/a
Pink/Black- n/a
Pink/ White- n/a
red- n/a
Green- from ignition switch cut this wire
Violet- to starter from wire I cut
Orange- n/a
Pink- from switch hot when on and cranking
It came in manual mode switched to auto also didn't know I had to have the parking brake wire hooked up. I have fixed those issues and it's not giving the error flashes.
This is going into a 81 regal so i don't have any immobilizers or anything of that sort.
Posted: October 24, 2017 at 8:17 AM / IP Logged Link to Post Post Reply Quote howie ll
Power the red.
jdigitty88
Posted: October 25, 2017 at 7:50 PM / IP Logged Link to Post Post Reply Quote jdigitty88
Thanks for that,
Hooked up the red to power and the red/black and bamm everything is working like it should.
for future reference.
Red/Black- power
Pink/Black- n/a
Pink/ White- n/a
red- power
Orange- n/a
Thursday, September 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
