If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Friday, April 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I am using that black and red wire for my door trigger (Viper 5706V) and I having issues. My dome light, ignition light, and exterior key light are all illuminated. The open door warning light is also illuminated. I am not entirely sure if that is the proper wire to use or should I use the red/white wire.
The reason I picked the black/red wire is out of convenience. I figured when the light turns on, it should ground the wire however, I might need a diode to block flow back from the alarm? I am a bit confused honestly.
