2003 Duramax Base Model, Viper 5906v Wiring
duramaxedx2
Posted: July 20, 2018 at 3:47 PM / IP Logged Link to Post Post Reply Quote duramaxedx2
hey yall i got a 2003 duramax base model crewcab and im installing a viper 5906v and was wondering where to tie in the door input or green wire on the 24 pin connector for the viper 5906v its a base model no power locks yet and no power windows everything ive checked into mentions a 26 pin connector in the door but dont have one i think i have everything else wired up right but just trying to find the best place to tie the door input in and if its under the dash at the bcm or at each door thanks in advance for any info
thanks for all the help you guys LOL
geepherder
Platinum - Posts: 3,668
Posted: July 20, 2018 at 5:21 PM / IP Logged Link to Post Post Reply Quote geepherder
Look for at the BCM for a grey/black wire and a black/white wire:
https://www.the12volt.com/installbay/forum_posts.asp?tid=11497
duramaxedx2
Posted: July 20, 2018 at 6:02 PM / IP Logged Link to Post Post Reply Quote duramaxedx2
thanks brother ill look into it tomorrow morning appreciate the quick responce man
duramaxedx2
Posted: July 30, 2018 at 7:58 PM / IP Logged Link to Post Post Reply Quote duramaxedx2
figured it out in case anyone else runs across this problem the door switch input for a 2003 duramax base model crew cab is located at the bcm connector c4 pins a5 right front black/white b4 left front gray/black the rear is going to be another connector located on the back of the bcm towards the firewall the connector is c6 pins a2 right rear green/black a3 left rear blue/black
duramaxedx2
Posted: July 30, 2018 at 7:59 PM / IP Logged Link to Post Post Reply Quote duramaxedx2
thanks geepherder for kicking it off man
