2008 Honda Accord, Aftermarket Push Start System
jdminspire
Posted: August 29, 2018 at 1:45 PM / IP Logged Link to Post Post Reply Quote jdminspire
I'm installing a push start system in my car I have it working the car starts and everything the system has a feature where the car is locked the push start is disabled and when the car is unlocked push guard is enabled for this system to work right I have to connect the positive white lock wire and a positive white and black unlock wire to cars lock and unlock wire. These are the wires for my car but they're negative pulse how do I convert it into a positive
Lock     ORANGE     IN THE DRIVERS DOOR #201
Unlock     BROWN ***     IN THE DR DOOR W DOUBLE PULSE
#201- See Negative Pulse Door Lock Diagram. * GREEN PLUG ** OF FUSE BOX WHITE PLUG *** From Installer- Unlock Requires BROWN And WHITE To Be Diode Isolated And Double Pulse For Unlock. Wires Found At Door Motor DOOR
the12volt
Administrator - Posts: 3,957
Posted: August 29, 2018 at 1:53 PM / IP Logged Link to Post Post Reply Quote the12volt
Wednesday, September 10, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
