Ford Powercode PATS Bypass
mikeluscher159
Member - Posts: 36
Posted: September 12, 2018 at 12:20 PM / IP Logged Link to Post Post Reply Quote mikeluscher159
Hi all,
I won me an old Code Alarm made Ford Powercode Gold dealer installed remote start for my '06 Taurus
But it seems the bypass kit it specifics is obsolete
Is there anything else that'll work or interchange for 1L2Z-19G365-AB
Thanks for the help
-Mike
Ween
Platinum - Posts: 1,368
Posted: September 12, 2018 at 7:34 PM / IP Logged Link to Post Post Reply Quote Ween
Should be able to use any transponder bypass that is compatible with Fords. There should be a blue/black in the 'B' harness that is
labeled active output...ground while running. It will have a ground signal when the remote start is operated. Hope this helps.
mikeluscher159
Member - Posts: 36
Posted: September 16, 2018 at 1:27 PM / IP Logged Link to Post Post Reply Quote mikeluscher159
I got a Fortin EVO-Key, because it's inexpensive and supports my vehicle, now my problem is how do I get it to interface with the Start module
The install instructions for the manual show me plugging into a 4 pin header connector on the module with the Ford bypass
None of the connectors on this Fortin seem to fit?
I can install the Fortin, and I can install the Remote start, I just don't know how they'll talk to each other
Ford Powercode PATS Bypass - Last Post -- posted image.
eguru
Copper - Posts: 340
Posted: September 16, 2018 at 7:52 PM / IP Logged Link to Post Post Reply Quote eguru
You need to make the connections per 1A in the installation guide.
Getting a 8L3Z-19G365-BA on eBay would probably have been simpler though.
mikeluscher159
Member - Posts: 36
Posted: October 18, 2018 at 5:02 PM / IP Logged Link to Post Post Reply Quote mikeluscher159
I see
I didn't know I had to do that cutting, but I did eventually figure it all out
I tried a 8L3Z, it doesn't clear the black key holder bezel thingy clipped to the barrel
It's designed for flat metal key surrounds
Thanks for all the help
chev104275
Gold - Posts: 1,436
Posted: October 18, 2018 at 7:34 PM / IP Logged Link to Post Post Reply Quote chev104275
In order to use the 8L3Z you need to pop out the ingition cylinder put on the ring then reinstall the cylinder.
