Skytek 2000RS Continuously Cranks
jmrwd3
Posted: November 19, 2018 at 11:14 PM / IP Logged Link to Post Post Reply Quote jmrwd3
Hello All, I have a 2006 Toyota 4Runner which I have owned for about 6 years. The vehicle had a Skytek 2000RS remote start, with a 556U immobilizer pod installed by the prior owner. The vehicle didn't come with the remote, and I finally got around to finding a replacement, which I successfully programmed today! And the unit worked great! But - I couldn't resist messing with something that worked, and attempted to enter some custom settings. In doing so, I reset the unit defaults, and now when I try and activate the remote start it just cranks the engine continuously :(
I found the manual online Skytek 2000RS Manual page 33 shows the programming options
Does anyone have experience with something like this? Any help would be greatly appreciated Skytek 2000RS Continuously Cranks - Last Post -- posted image.
iskidoo
Silver - Posts: 1,046
Posted: November 20, 2018 at 2:51 AM / IP Logged Link to Post Post Reply Quote iskidoo
Call tech support Mon-Fri from 8:00AM to 4:00PM Pacific Time at   (818) 252-6678 or (818) 767-8593.
Steve G
iskidoo
Posted: November 20, 2018 at 3:06 AM / IP Logged Link to Post Post Reply Quote iskidoo
I'd probably start by changing branch 14 to tach monitor. Then try the RPM learn routine on branch 15 and see what happens. Hopefully someone wired up the tachometer wire when it was originally installed.
Steve G
iskidoo
Posted: November 20, 2018 at 3:12 AM / IP Logged Link to Post Post Reply Quote iskidoo
Is it possible that this is the manual?
2000RS
Steve G
jmrwd3
Posted: November 20, 2018 at 7:09 AM / IP Logged Link to Post Post Reply Quote jmrwd3
I bet that is the manual since the unit is from 2006, good catch!!
I bet that also means I purchased the incorrect replacement remote... The one I bought looks like this, perhaps I am not able to correctly program things.
jmrwd3
Posted: November 20, 2018 at 7:11 AM / IP Logged Link to Post Post Reply Quote jmrwd3
Thanks for the help Steve!!
I tried the RPM learn feature, however it give me the 4 click response, which I from the manual indicates it could not learn the signal.
Tuesday, November 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
