Relay Wiring, Siren With Negative Door Trigger
gern
Posted: August 08, 2019 at 8:54 PM / IP Logged Link to Post Post Reply Quote gern
I have installed a simple alarm to my 1999 GMC Sierra connecting from the door light switch to an on/off toggle switch to a siren. The door switch is 12v constant until door opens sending a negative pulse. I have wired the siren positive to a constant 12v fused. The negative wire of siren is run to the toggle switch/door light switch. Now this is sending 12v both thru the positive and negative to the siren when the door is closed and activates with the negative pulse when door is open. This set up works fine however it is concerning having 12v on both legs. Should this be run thru a relay converting the negative pulse to positive and just grounding the siren or is there a relay configuration I can use with existing set up?
Gern B.
Platinum - Posts: 13,726
Posted: August 08, 2019 at 10:31 PM / IP Logged Link to Post Post Reply Quote i am an idiot
If it is working all is good.
gern
Posted: August 09, 2019 at 7:38 AM / IP Logged Link to Post Post Reply Quote gern
Thank you
Gern B.
