2007 Chevrolet Aveo Disarm/Lock/Unlock Wire
sand33p_sidhu
Member - Posts: 25
Posted: August 20, 2019 at 12:00 AM / IP Logged Link to Post Post Reply Quote sand33p_sidhu
Greetings,
I have installed a remote start using CM900 Compustar module and I have been having hard time finding lock, unlock & disarm wire. According to bulldog security wiring diagram, lock & unlock wires are supposed to be in driver's kick harness but had no luck, disarm wire is supposed to be in driver's door harness, its not there.
According to some of the other wiring diagrams, lock & unlock wire is supposed to be on the pass. kick panel and I don't see anything.
Anyone got any idea? I just want to disarm the alarm when the car starts, I would be okay without the lock & unlock. Any other idea of disarming the alarm when remote start starts the car?
Any help is appreciated!
Platinum - Posts: 13,725
Posted: August 20, 2019 at 10:23 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Power Lock      lt. blue      -      driver kick, white 20 pin plug, pin 8
Power Unlock      white      -      driver kick, white 20 pin plug, pin 9
Lock Motor      gray      5 wire      driver kick, white 20 pin plug, pin 1
Driver Unlock Motor      brown      5 wire      driver kick, white 20 pin plug, pin 2
Passenger Unlock Motor      no progressive unlock
Factory Alarm Arm      factory remote only
Factory Alarm Disarm      lt. grn/red or brn/blk to pur (dr door key unlock)      -      driver kick, white 20 pin plug, pin 12
sand33p_sidhu
Member - Posts: 25
Posted: August 20, 2019 at 12:09 PM / IP Logged Link to Post Post Reply Quote sand33p_sidhu
Thank You for the information.
Do you know if i would need to use any relays to make lock & unlock work? According to bulldog security, it says it is a Type B lock & unlock.
Posted: August 20, 2019 at 4:15 PM / IP Logged Link to Post Post Reply Quote i am an idiot
No relays needed. Connect your alarm's lock wire to the Lt. Blue mentioned above, and connect alarm's unlock wire to the white mentioned above.
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
