2000 Chevrolet Blazer, Viper 5305v
provolone
Posted: January 13, 2020 at 11:29 AM / IP Logged Link to Post Post Reply Quote provolone
Hi everyone I need some help viper 5305v I have a 2000 Chevy blazer I have one wire for factory disarm the viper has two Wires factory arm and factory disarm so do both these wires get used or just one and would I need a relay as well thanks. Also another problem is what do I hook up so my alarm will go off if I open the doors the dome light or the door pins thanks
Provolone
mgoetz74
Silver - Posts: 424
Posted: January 13, 2020 at 12:02 PM / IP Logged Link to Post Post Reply Quote mgoetz74
i wouldn't worry about the are wire since chevy arms on lock just to the disarm wire, no relay needed-
Factory Alarm Disarm lt. green (driver door key cylinder)- BCM in center console below radio, purple plug, pin B3
as for the door triggers use the green door trigger on the viper
Left Front Door Trigger       tan     BCM in center console below radio, purple plug, pin B4
Right Front Door Trigger     orange          BCM in center console below radio, purple plug, pin B2
Left Rear Door Trigger     dk. blue/white     -     BCM in center console below radio, lt. blue plug, pin B11
Right Rear Door Trigger     same as left rear door trigger
provolone
Posted: January 13, 2020 at 12:36 PM / IP Logged Link to Post Post Reply Quote provolone
Ok do I need to Diode Isolate the door triggers I have in4007 rectifier Diode if yes will that work
Provolone
provolone
Posted: January 27, 2020 at 11:22 AM / IP Logged Link to Post Post Reply Quote provolone
Hi I have a 2000 Chevy blazer I have a viper 5305v remote start and security I have everything hooked up and working fine except for horn honk I hooked it up to the schematic for the horn and still have nothing wanted to know if it’s something to pre-program from factory to stay off and I would have to turn it on or is there a way I can test that the brown /black wire has 200ma
Provolone
geepherder
Platinum - Posts: 3,668
Posted: January 27, 2020 at 1:50 PM / IP Logged Link to Post Post Reply Quote geepherder
You can see if the output is enough to trigger a relay. Connect terminal 85 to the horn output wire of the alarm. Connect 86 to positive 12 volts. Set and trigger the alarm (open a door, etc.). Feel/listen to the relay to see if it's clicking. If it is, the output of the alarm is working.
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
