remote lead Relay
Sebastian018
Silver - Posts: 364
Posted: June 08, 2003 at 2:32 PM / IP Logged
HI, I need to know how to hook up the relay to connect the Remote lead to three amplifiers,?
thank you
Platinum - Posts: 12,488
Posted: June 08, 2003 at 2:56 PM / IP Logged
Use this digram for multiple remote amp leads: Positive to Positive Relay Diagram
ivanp2
Member - Posts: 10
Posted: June 11, 2003 at 3:11 PM / IP Logged
I was wondering the same thing. So how do you actually use this. I understand the diagram, but how do you run this out to multiple amplifiers?
xetmes
Silver - Posts: 586
Posted: June 11, 2003 at 3:45 PM / IP Logged
hook the remote output of the headunit to the relay ciol, the other to ground (85, 86). then hook up a good fused 12 V source to pin 30, then hool up all the remote inputs on the amps to 87 of the relay, yes hook them all up to this one pin, it will then be able to handle the current load.
ivanp2
Member - Posts: 10
Posted: June 11, 2003 at 3:47 PM / IP Logged
Thanks for the info.
Sebastian018
Silver - Posts: 364
Posted: June 14, 2003 at 7:35 PM / IP Logged
you know I was told to do it this way
85= Remote from the head unit (usually Blue)
87= Constant Fused 12+
86= Ground
30= all the remote inputs on the amps
I dont know If its right. I planning to do it tomorrow....
Let me know thank you
xetmes
Silver - Posts: 586
Posted: June 15, 2003 at 7:55 AM / IP Logged
yea that will work. remote lead  Relay - Last Post -- posted image.
Sebastian018
Silver - Posts: 364
Posted: June 15, 2003 at 7:59 AM / IP Logged
ok, thank you
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
