Clifford Intellistart 1, JDM 1990-91 Honda Integra
nadeem mohammed
Posted: July 07, 2020 at 11:52 AM / IP Logged Link to Post Post Reply Quote nadeem mohammed
Good day I'm new to this site & I'm not sure how to create my own post so i need some advice. I'm also trying to install the Intellistart 1 to a Clifford concept 470, does the gray/violet wire from Intellistart goes directly to the alarms accessory output 2? Or it needs a relay? Also there are 2 white/brown wires one is saying to connect to vehicle ignition and the other is saying the alarms ignition sense wire. Im confused what they are saying, I know my alarm immobilizer already cut the main ignition wire which is black/yellow and my other ignition which should be #2 is blue/white. I own a JDM 90-91 Honda Integra which is almost the same as 90-93 Acura Integra in the USA. Any help.
nadeem mohammed
Posted: July 12, 2020 at 1:28 PM / IP Logged Link to Post Post Reply Quote nadeem mohammed
Ok any help, so I finally got it to remote start. I've got 2 problems now under the test procedure, it cuts off with both brake pedal and good pin when remote start but it grinds the starter when the said the safeguard will avoid this. Also it only remote starts when the alarm is off, if activated the remote won't do nothing but it says that the sensor interrupt is not needed on the concept model which is what I have Clifford concept 470 and Intellistart 1
Wednesday, September 10, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
