Compustar CM6000 Firmware Update? X1 Drone Not Communicating
Platinum - Posts: 7,828
Posted: August 31, 2020 at 11:58 AM / IP Logged Link to Post Post Reply Quote kreg357
Sounds good. You can flash the Blade AL with plain "TB" firmware.
qpham504
Copper - Posts: 51
Posted: September 02, 2020 at 2:55 PM / IP Logged Link to Post Post Reply Quote qpham504
UPDATE
It was def the TB blade. The AL blade arrive 2hrs ago right when I pulled up to the house with my bro's truck so I just jumped right into it. Swapped the blade, flashed the firmware, captured a key, verified arm/disarm, lock/unlock, programmed tach, remote start. Re-installed the x1 drone and VOILA, it worked. Thanks guys. 12volt is so much better than firsttech customer support.
silvercivicsir
Copper - Posts: 416
Posted: September 02, 2020 at 4:21 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
Nice, glad my "random" reading was helpful!
qpham504
Copper - Posts: 51
Posted: September 02, 2020 at 5:12 PM / IP Logged Link to Post Post Reply Quote qpham504
Every little bit helps. It's better than hearing 'oh your brain doesn't have a firmware update' and that would be the end of it.
Page of 3
