Scytek A15 Light Flash Output, 2009 Dodge Ram
aaron hernandez
Posted: December 16, 2020 at 7:42 PM / IP Logged Link to Post Post Reply Quote aaron hernandez
Hi im new to the group and having problems with the scytek a15 powerlocks. I have everything connected and working except for the light flash output i have tried to connect to the parking lights but nothing flashes i know the wires are getting power. Its a 2009 dodge ram and i may be a little bit of a noob to this so anything helps. Im all out of ideas on where to try to connect it.
Aaronh.h
Platinum - Posts: 7,827
Posted: December 16, 2020 at 8:53 PM / IP Logged Link to Post Post Reply Quote kreg357
There are a couple of ways to achieve this. If you want to stay inside the cab, use the Light MUX wire. Set the A15 to (-) Parking Light output.
Place a 1.1 k ohm resistor in the A15 Parking Light output wire and connect to this wire listed below :
PARKING LIGHTS ( - )     WHITE (- THRU 1,000 OHM RESISTOR)     @ HEADLIGHT SWITCH, PIN1, BLACK 10-PIN PLUG
Please note that some wire guides list the White/Green wire on this plug instead of the White wire. Additionally, DEI suggests use of TechTip 1082.
Bulldog Security lists a 1 k ohm resistor so be prepared to do some testing to determine the best resistor value.
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
