Compustar 7200, 2002 Toyota Sequoia Problem
furious440
Member - Posts: 8
Posted: December 29, 2020 at 10:54 PM / IP Logged Link to Post Post Reply Quote furious440
Hello Ladies & Gents!
I am new to Compustar. Very experienced with DEI.
I have a problem with a 2002 Sequoia Limited with factory security. I am using the Ground When Armed, blue/white wire on CN5 to disarm the factory alarm at the 2 pin connector at the ignition switch. It is soldered to the yellow/green wire.
It will remote start. But will cause the factory alarm to honk the horn until the engine fires! What am I missing here? Any help is greatly appreciated!
MX6boii
Copper - Posts: 74
Posted: December 29, 2020 at 11:07 PM / IP Logged Link to Post Post Reply Quote MX6boii
Hey Furious440,
I just checked the wiring diagram on this unit. Why not use Pin 9 Orange/Black on that harness which is for Factory Alarm Disarm? Will provide a negative pulse during unlock and ground when running during the remote start sequence also.
furious440
Member - Posts: 8
Posted: December 29, 2020 at 11:36 PM / IP Logged Link to Post Post Reply Quote furious440
Thanks for the reply MX6boii
I was just looking at that too. You may just have the answer. Thank you.
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
