Polar Starter PS-2905 Replacement Parts, 1999 Ford F-150 XL
lbrowne
Member - Posts: 19
Posted: December 20, 2021 at 12:56 PM / IP Logged Link to Post Post Reply Quote lbrowne
Hello all,
I have this old remote starter that's in an old base model 99 f150, no power door locks or anything. Just the remote start feature is used.
The starter has practically 0 range because the antenna is damaged. I was thinking I might be able to install a new antenna or even swap out the module to a newer model if I could reuse the existing harness. Anyone familiar with these units or know of a model I can swap in fairly easily?
I change cars too often to put one here.
iskidoo
Silver - Posts: 1,046
Posted: December 24, 2021 at 12:54 PM / IP Logged Link to Post Post Reply Quote iskidoo
Harnesses won’t just plug in but it would be easy enough to connect all the existing wires to a new harness on brand new unit with superior range. Don’t fight with trying to adapt a 20 year old system. Just get a brand new system with new remotes. Maybe even 2-way.
Steve G
lbrowne
Member - Posts: 19
Posted: December 27, 2021 at 4:17 PM / IP Logged Link to Post Post Reply Quote lbrowne
That sounds even better - I might be able to cross-reference the wiring. (edit: maybe polar starters aren't made anymore?)
I'll see if I can locate the manual for the wiring schematic of the current one in there.
Cheers!
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
