Python 4105P Remote Start, 1995 Subaru Impreza
mjm4jc
Member - Posts: 17
Posted: January 03, 2022 at 1:29 PM / IP Logged Link to Post Post Reply Quote mjm4jc
Perhaps I need to make sure that the virtual tach is programmed????
Platinum - Posts: 7,828
Posted: January 03, 2022 at 3:04 PM / IP Logged Link to Post Post Reply Quote kreg357
Take a look at the 4105 programming options. Menu 1 Feature 1 is for the Horn function. The Factory Default is OFF. I would change that setting to Option 2 (20 mSec) or 3 (30 mSec). This will give you the desired results.
Posted: January 03, 2022 at 3:08 PM / IP Logged Link to Post Post Reply Quote kreg357
mjm4jc
Member - Posts: 17
Posted: January 04, 2022 at 10:27 PM / IP Logged Link to Post Post Reply Quote mjm4jc
Yeah I thought I did that. It took me a while to get used to the programming. I will go through the horn programming again. Also, In menu 2, feature 2, I can program the engine run time. But then it also has a timer mode run time?????? It's in menu 2, feature 11. Not sure what that is. Anyway,I started it today with the remote, and it started on the 2nd try. But once it was running, I was not able to use the remote to unlock the doors. Didn't think this was normal. Is this a programming issue?
Posted: January 05, 2022 at 5:00 AM / IP Logged Link to Post Post Reply Quote kreg357
Timer Mode :
Selects the time in minutes that the system operates the engine until the system “times out” when the remote start activates in timer mode. The system may be shut down using a shutdown at any time. More Timer Mode info can be found on the bottom of Page 5 of this 4105V manual : https://www.the12volt.com/installbay/file.asp?ID=1307
Re: Unlock while engine is running
Which FOB are you referring to ( Factory RKE of 4105V ) ?
It's not unusual for the Factory FOB to be inop during engine run time. With the engine running after normal key start up do the Factory FOBs work? If you are referring to the 4105 remotes, do they lock and unlock the doors with the engine off? Did you add solenoid actuators in the doors?
catback
Silver - Posts: 703
Posted: January 05, 2022 at 2:44 PM / IP Logged Link to Post Post Reply Quote catback
mjm4jc wrote:
But I am confused as to why it doesn't chirp on start up? I thought the main reason for the horn is to give the driver an audible signal that the car is started and running? Please advise.
The horn doesn't sound during a remote start, the parking lights are the only indicators for the remote start signal received and remote start engine running. The horn will chirp (as well as the parking lights flash) to make you aware of lock and unlock commands. Aside from remote starts that trigger on 3x Lock, I'm not aware of any remote starts that make audible tone from the vehicle before or during a remote start.
mjm4jc
Member - Posts: 17
Posted: January 05, 2022 at 6:06 PM / IP Logged Link to Post Post Reply Quote mjm4jc
mjm4jc
Member - Posts: 17
Posted: January 08, 2022 at 2:37 PM / IP Logged Link to Post Post Reply Quote mjm4jc
Page of 3
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
