Viper 5706v Alarm Kill Switch
6ix5
Posted: May 20, 2022 at 8:18 PM / IP Logged Link to Post Post Reply Quote 6ix5
Hey guys looking for some help. I have looked into this forum MAN..... there alot of info on here. So i purchased 5706v from Ebay looks like i may have a bad internal relay. i wired everything up with ease since I have a 1965 gmc. i have change the anti grind from off to on and back nothing works. I'm still able to fire up the engine while the alarm is going off. So after a few days of looking on here for for a diagram on how to wire up a relay as a kill switch i got it to work now my issue is that when you use the remote start it also engages the kill switch. so im assuming the GWA is being used as the remote start is applied. any work around??? either from what i got going on now or even trying to get back to using the green and violet wires to work..?
1965 GMC and 1961 GMC caryall
6ix5
Posted: May 20, 2022 at 9:03 PM / IP Logged Link to Post Post Reply Quote 6ix5
ok does the pink wire need to be connected in order for the kill switch to work?
4 PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT
iskidoo
Silver - Posts: 1,046
Posted: May 22, 2022 at 2:24 PM / IP Logged Link to Post Post Reply Quote iskidoo
Maybe you have the key side nd starter side cut wires reversed. Double check that.
Steve G
6ix5
Posted: May 22, 2022 at 7:31 PM / IP Logged Link to Post Post Reply Quote 6ix5
i double checked... i actually fixed it by running and external relay... 5 pin it kills the starter but if you do remote start it will actually work.
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
