2004 Nissan Titan, Simple Compustar Remote Start/Alarm Install Tip
jmaybes
Member - Posts: 7
Posted: November 12, 2022 at 12:13 AM / IP Logged Link to Post Post Reply Quote jmaybes
Hi, not sure if this is the correct location, mods please move if needed.
This is for those that may still have yet to install Compustar Remote Start / Alarm on a 2004 Nissan Titan. Compustar conveniently leaves out only the 2004 from benefiting from the Nissan installation T-harness. So much so that if you use one of Compustars models that must be flashed before install, like the CM-DC3, it will recommend (force) a different firmware for the 04 Titan, different from the 05-15 models, that does not work with t-harness.
Well forget thaT, if you have a 2004 Nissan Titan and go this route, choose 2005 before flashing your module, NOT 2004. Go ahead and flash, choose T-harness installation. Install with T-harness, program the module to your truck, and done. Total install time took me about 15min. This does not include the time I spent lost to first loading 04 firmware, finding out it does not work with t-harness, etc.
Hopefully this saves at least one other person out there because this info did not exist anywhere before this.
