If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Are there any other key fobs, with screens, that would work with this system? I installed an EFI system that has a can bus if that helps with add ons. I like the smart key LCD fobs, but I don't think they work with my old car. I don't have a start button, I need to turn a key in the ignition switch.
I'm still working on the car. Everything related to alarm and power doors and such seems to work, except for the remote start. Before I start looking for a wiring issue, just curious if the open brake system is triggering the inhibit icon on the remote screen. The car basically has no brakes hooked up so the dash brake light is on. I'm assuming this affects the switch at the brake pedal and makes the remote start function unavailable?
Thanks!
