2016 Toyota Camry, Remote Start Error
baby007
Member - Posts: 30
Posted: March 10, 2025 at 12:02 AM / IP Logged Link to Post Post Reply Quote baby007
Hi, I'm installing with Compustar CMX,T13 remote, and Blade module. All lock, unlock, alarm functions are working fine. Every time I remote start, the light on the Blade flash blue one, and solid red for 1 - 2s then turn off. Dashboard and odometer light turn on but car wouldn't start. It then turn everything off, try to start again, dashboard and odo are on again. It keeps doing that for I think 3 times then gives up.
Does that mean I have an "Incorrect Programming" error? (according to idatalink)
lee.lopez
Copper - Posts: 307
Posted: March 10, 2025 at 5:22 AM / IP Logged Link to Post Post Reply Quote lee.lopez
Your 2 way remote will give you a start error code.
A solid red on the Blade LED is "waiting for more vehicle information". You might try a factory reset and then reprogramming if that doesn't work.
baby007
Member - Posts: 30
Posted: March 30, 2025 at 12:20 PM / IP Logged Link to Post Post Reply Quote baby007
There was no error shown on the remote. I swap out the brain and everything working now.
One more thing is how would you set the runtime on the OP500 to something like 10 minutes?
I believed we need an updated OP500 but not sure how to check if mine is already up to date?
Manual saying you need to select option 4 for Group 2-7 (for runtime 3-45 min). After choosing option 4, how do you specify the exact runtime?
Thank you
lee.lopez
Copper - Posts: 307
Posted: March 30, 2025 at 4:51 PM / IP Logged Link to Post Post Reply Quote lee.lopez
Keep scrolling and you will see after menu 4. It'll be in special features. Same thing if you choose to change defrost temperature.
baby007
Member - Posts: 30
Posted: April 16, 2025 at 9:38 PM / IP Logged Link to Post Post Reply Quote baby007
Found it.
Thanks alot
One more question, when wiring table says "Left Front Window (Up/Down) (motor is part of module)", does that mean one touch window module not compatible?
lee.lopez
Copper - Posts: 307
Posted: April 17, 2025 at 4:44 PM / IP Logged Link to Post Post Reply Quote lee.lopez
I've never messed with one of those window modules, so I couldn't tell you.
Wednesday, April 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
