2007 Honda CR-V, Viper 4105V With DB3
robo308
Posted: January 29, 2026 at 2:41 PM / IP Logged Link to Post Post Reply Quote robo308
I purchased a Viper 4105V/DB3 combo, the DB3 came programmed for the '07 CRV. I got both modules wired per the DB3 wiring diagram, and only the door lock/unlock functions. The viper remote arms and disarms the factory alarm, flashes the P lights, and flashes the blue security LED on the Viper antenna, so I believe the DB3 has been flashed correctly, but the remote start does not respond.
The vehicle is a key start.
Just to note my skill level, I am a Mechanical Engineer, and have been building and restoring automobiles for over 40 yrs. I have built and reconstructed wiring harnesses.
To give some particulars on the installation: I got a detailed wiring diagram for the DB3 on the 2007 CRV, but nothing specific on the Viper 4105V. The DB3 diagram just shows a block for a remote start module with only 7 of the many wires connected to the car.
I made all the instructed DB3 connections, and the indicated connections on the 4105V module with the exception of the hood pin (waiting to test if needed, I believe there is a factory hood open signal). On power up the LED on the DB3 indicated successful programming.
Below is a summary of what I did and did not connect on the Viper 4105V module:
-Remote start harness, 5 pin white connector - I have none of these connected, in fact it is not even plugged in. Should any of these wires be connected?
   Pin 1) Parking brake input - not connected, I don't think it's needed, car has an automatic transmission
   Pin 2) Tachometer input - not connected, doesn't DB3 take care of this?
   Pin 3) Brake shutdown input - not connected, not sure what this signal does
   Pin 4) Hood pin shut down - not connected, waiting to see if needed, my other CRV has a factory hood open signal
   Pin 5) Rear defogger output - not connected, but I would like the rear defogger to go on in the winter
-Main harness, 9 pin white connector
   Pin 1) factory alarm disarm - not connected, but functioning with Viper remote
   Pin 2) factory alarm disarm - not connected, but functioning with Viper remote
   Pin 3) Ignition out to alarm - not connected is this needed, I don't have a Viper alarm?
   Pin 4) Activation input - not connected, not sure where this would be connected to?
   Pin 5) Anti-Grind - not connected, not sure where this would be connected to?
   Pin 6) Horn output - not connected I think I need this, horn is not sounding when locking the doors
   Pin 7) Trunk release - not connected, I don't have a trunk release
   Pin 8) Chassis ground - connected, good connection to chassis
   Pin 9) light flash output - connected, P lights flash on lock and unlock, I must have got the light flash polarity jumper in the correct position.
-Heavy gauge relay harness, 6 pin white - all pins connected
-Door lock harness, white 3 pin - did not use
-Satellite harness, white 4 pin - did not use
-D2D harness - all pins connected, viper module to DB3
Are any of the wires that I did not connect prohibiting the remote start from functioning?
Is there some programming to the 4105V module that I missed.
Any help would be much appreciated.
jrjr
Platinum - Posts: 7,828
Posted: February 04, 2026 at 5:46 PM / IP Logged Link to Post Post Reply Quote kreg357
Here are some answers...
First caveat...   I am not a DB3 user and am unable to get any specific info on the capabilities of this module when it is flashed with the Honda4 firmware. The good news is I have used plenty of Viper 4105 units and even had a 2007 CR-V that I installed a basic R/S system into.
    This wire is actually called the Neutral Safety and needs to connected to supply a ground for the R/S to work.
     You are correct that a vehicle with an Auto Trans you can just connect it to a good Chassis Ground point.
      As mentioned, I don't know the capabilities of the DB3 but most decent similar bypass module ( EVO-ALL and
      ADS AL-CA ) do supply a Tach signal in this application.
     This input signal has a few purposes. It is primarily used for "Key-take -over" and as a R/S shutdown.
      The similar bypass module mentioned previously do not supply a Brake signal so it's very possible that you will have to hardwire this signal, info below :
      Brake Detection    LIGHT GREEN    (+) AT SWITCH ABOVE BRAKE PEDAL
      You can test this by doing a R/S and then depress the Brake pedal - engine should shutdown.
      The DB3 might supply this signal. Easy to test, just R/S engine and pop hood.   This is an important safety
       feature. Install the 4105 kit supplied Hood Pin if necessary.
        Another wire with a couple of uses.
        You will have to program the Viper Menu 2, Feature 8 to Option 2
       Rear Defrost    BROWN    (-) LINK CONN. ABOVE GAS PEDAL
   Not needed.
    Not needed. Could be used for test purposes.
    If you added a relay on the vehicles' Starter wire, you could use this signal to prevent the driver from engaging the starter during key take over.
    Optional but nice to have. Here is the vehicle info :
    Horn Honk    ORANGE    (-) IGNITION SWITCH HARNESS
    Viper programming   Menu 1 Feature 1 Option 2
Heavy gauge 6 Pin
1 RED (+) (30A) HIGH CURRENT 12V INPUT        White
2 PINK/WHITE (+) PROGRAMMABLE OUTPUT      Optional - Red set to ACC2 Menu 2 Feature 2 Opt 2
3 RED (+) (30A) HIGH CURRENT 12 INPUT           White
4 ORANGE (+) (30 AMP) OUTPUT TO ACCESSORY             Orange
5 PURPLE (+) (30 AMP) OUTPUT TO STARTER    Yellow
6 PINK (+) (30 AMP) OUTPUT TO IGNITION CIRCUIT            Blue
Yes. Neutral Safety to Chassis Ground.
I don't like Virtual Tach. Assuming the DB3 supplies a Tach Signal...
Set Viper to Tach Mode ( Menu 2 Feature 1 Option 4 ) and do a Tach Learn.
Good luck.
Cheers
