Denali-Cherokee 2001Speed
danber
Posted: July 30, 2003 at 2:12 PM / IP Logged
Hello,
I need the wiring color and location of the Speed signal for a 2001GMC-Denali and a 2001 Jeep Cherokee.
Also, I need to know how many pulses per mile for both vehicles.
Than you,
 Dan.
airandsound
Copper - Posts: 69
Posted: August 02, 2003 at 10:37 AM / IP Logged
denali is at teh cruise plug at the firewall never the mastercylinder,,POS K GREEN / WHITE, 4000 pulse.
Cherokee is 8,000 pulse and at the PCM white 32 pin plug #27 white /orange wire
CruiseCoast
Member - Posts: 10
Posted: August 02, 2003 at 10:39 AM / IP Logged
Dan, On the GMC Denali There should be a connector somewhere near the MasterCylinder near the firewall with about seven or eight wires going to the cruise unit (or capped with a plug if no cruise) The Dark Green wire with a white trace will be your VSS wire. And it should be set at 4000 pulses.
The 2001 Jeep 4.0 engine. The VSS wire from the transmission will be the orange wire with the white trace and you can set the pulses on 8000.
Good luck!
Douglas Walker
SellersAuto Air & Cruise
Gulfport, Ms
Do it right do it once!
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
