2003 Infiniti G35 Coupe Alarm/Remote Start/Stereo Wiring
almeida79
Member - Posts: 47
Posted: August 12, 2003 at 7:16 PM / IP Logged
hello does anyone have a remotestart/alarm wiring diagram for an 03 infiniti g35 coupe thanks in advance
Jay
Montrealler
Copper - Posts: 155
Posted: August 12, 2003 at 8:51 PM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|WHITE/ blue          |+ |ignition harness            |
|          STARTER|WHITE/ red           |+ |ignition harness            |
|   SECOND STARTER|WHITE/ green        |+ |ignition harness            |
|        IGNITION|BLACK/ red           |+ |ignition harness            |
|        ACCESSORY|WHITE/ black        |+ |ignition harness            |
|       POWER LOCK|RED / white *1        |- |driver switch in door       |
|     POWER UNLOCK|blue/white *1       |- |driver switch in door       |
|       LOCK MOTOR|purple              |   |wht plug, pin 30 @ BCM *2   |
|     UNLOCK MOTOR|yellow              |   |wht plug, pin 23 @ BCM *2   |
|    DISARM DEFEAT|WHITE/ blue          |   |wht plug, pin 31 @ BCM *2   |
| PARKING LIGHTS +|RED / blue            |   |driver kick panel           |
|       HEADLIGHTS|RED / blk (L), red (R)|+ |wht 12 pin plug, IPDM E/R *3|
|     DOOR TRIGGER|*4                  |- |wht 12 pin plug @ BCM *2    |
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|RED / white           |- |wht plug, pin 18 @ BCM *2   |
|        HOOD PIN|lt GREEN/ black      |- |pin switch under hood       |
|TRNK/HTCH RELEASE|blue               |- |brn plug, pin 76 @ BCM *2   |
| FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|*1                  |   |                            |
|       TACHOMETER|NOT black or wht/blu|   |any ignition coil           |
|      SPEED SENSE|WHITE/ green        |2 |cluster, brn plug, pin 19   |
|       BRAKE WIRE|pink/blue           |+ |brake pedal switch          |
|     HORN TRIGGER|GREEN/ black        |- |steering column             |
|           WIPERS|purple(L),blu/blk(H)|- |wiper motor                 |
| LF WINDOW UP/DN|*5                  |   |                            |
| RF WINDOW UP/DN|                    |   |                            |
| LR WINDOW UP/DN|                    |   |                            |
| RR WINDOW UP/DN|                    |   |                            |
| SUN RF OPN/CLOSE|not recommended     |   |                            |
|        RADIO 12V|yellow              |+ |radio                      |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|lt green            |+ |radio                      |
| RADIO ILLUMINATE|RED / blue            |+ |radio                      |
|    POWER ANTENNA|grn/wht or RED / wht |+ |radio                      |
|       LF SPEAKER|wt or bu-bk or bk/wt|   |radio or amplifier *6       |
|       RF SPEAKER|gn or br-re or bk/re|   |radio or amplifier *6       |
|       LR SPEAKER|br or l gn-y or bk/y|   |radio or amplifier *6       |
|       RR SPEAKER|bu or or-pk or bk/pk|   |radio or amplifier *6       |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555U. *1 These are the driver door key cylinder wires. Meter the wires while turning the key in the driver door. Single pulse on the unlock wire will disarm the alarm without unlocking the doors. Unlock requires a double pulse. *2 The BCM (Body Control Module) is in the driver kick panel. *3 The IPDM E/R (Intelligent Power Distribution Module Engine Room) is between the passenger fender and the battery. *4 The driver door trigger is white in pin 14, the front passenger door is pink in pin 10, and the rear door trigger (on vehicles without navigation) is pink in pin 11. On vehicles with navigation system the rear door trigger wire does not go to the BCM, instead use 2 separate pink wires in the driver kick panel in the harness that runs to the rear. Use all wires and diode isolate each. *5 Extended triggers on the power door lock wires will roll the windows up and down. *6 The amplifier is under the rear deck.
Tuesday, June 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
