2003 dodge 1500
ddoige
Posted: August 22, 2003 at 4:05 PM / IP Logged
can anyone send me anything on door panel removal on 2003 dodge 1500 single cab. I don't want to wing it and thrash the new truck. please contact daved@raysradio.com
                                      thanx
JR_Performance
Posted: August 25, 2003 at 2:25 PM / IP Logged
I havent worked on a brand new dodge ram, but the older rams (98,99, etc.) had plastic pop pins on the door panel that pop off once the initial screws have been taken off. the plastic pins are brittle and can break easily so, use a panel popper.
jabpreston
Member - Posts: 8
Posted: August 26, 2003 at 7:39 PM / IP Logged
Just remove the phillips screw by the inner door handle and then remove the bolt that  holds the door handle on, to remove the handle.  You can see the bolt thru the door handle hole.  Then just lift up on the door panel and disconnect the wires.
jabpreston
