1999 Ford Ranger Door Switch
Tim Coyle
Posted: September 06, 2003 at 11:14 AM / IP Logged
I have had 3 door switch failures since I bought this Ranger new in '98. It is the most annoying thing. The door ajar light comes on and though there appears to be a timer that shuts off the dome light after about 20 minutes, it's enough to cause battery failure because I never shut off my radar detector. Each replacement has cost about $180. because of labor. The switch is a Motorcraft SW-5528. Does anyone have the wiring diagram for this circuit? Does anyone know if this switch can be by-passed? I am in a fail mode now and I do not want to replace it if I can get around it. Or perhaps there is another, more reliable switch?
Thanks for your help.
timcoyle@hotmail.com
auex
Platinum - Posts: 5,041
Posted: September 06, 2003 at 3:32 PM / IP Logged
Do you have anything wired to the switch?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Tim Coyle
Posted: October 07, 2003 at 3:39 PM / IP Logged
No, I do not have anything added to this circuit. Does anyone have the wiring diagram for this circuit?
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
