autopage rs-850 lcd
almeida79
Member - Posts: 47
Posted: August 12, 2003 at 7:11 PM / IP Logged
Hello im looking for a installation/user manual for a autopage rs-850lcd remote car starter alarm  thanks in advance
Jay
almeida79
Member - Posts: 47
Posted: September 19, 2003 at 8:40 AM / IP Logged
Is there a way to make the autopage rs-850 lcd disarm itself automatically  when activating trunk release on the remote  because it triggers alarm as soon as you lift the trunk  lid is there a way to make it disarm itself  when you push the trunk release for two seconds to activate trunk popper so it does not trigger alarm.
Jay
almeida79
Member - Posts: 47
Posted: September 19, 2003 at 4:19 PM / IP Logged
I guess the only way is to disarm and unlock doors first then press trunk release autopage rs-850 lcd - Last Post -- posted image.
Jay
almeida79
Member - Posts: 47
Posted: September 20, 2003 at 9:26 AM / IP Logged
Another? does this also apply to the 750 lcd ?
Jay
Derekc
Member - Posts: 34
Posted: September 21, 2003 at 8:09 PM / IP Logged
I think the AUTOPAGE RS_850LCD is same as COMMANDO FM-870 here:
http://www.commandocaralarms.com/itemdetails.asp?Productid=1185
Which is also the same as M-3600 (by Megatronix) promoted by WWW.ASIANWOLF.COM.
They all share the same brain and I have so much problem with this product.
The manual is here:
http://www.commandocaralarms.com/manuals/FM-870install.pdf
dc
Derekc
Member - Posts: 34
Posted: September 21, 2003 at 8:10 PM / IP Logged
One of many problems I found when trying to install one (or two) of these AUTOPAGE / COMMANDO / MEGATRONIX M-3600 2-way pager LCD remote start alarm is this even the programming features specifically mentions you can set to disarm when activiating channel 3 (when is the trunk). It just doesn't work.
Other problems:
1. It gives a ground pulse on channel 4 and 5 when disarm. I have my windows rolling module hooked up to channel 4 and everytime it disarms, the front doors crack opens a bit.
2. The programming reset to default features (for both alarm and remote start) don't clear and reset anything.
3. Very short signal distance - about a block.
4. Very badly written manuals
5. .....
dc
almeida79
Member - Posts: 47
Posted: September 22, 2003 at 5:34 AM / IP Logged
The feature you are programing is to disarm the cars factory alarm wich when programed it sends a neg pulse thru the disarm wire when you active the trunk release
Jay
