the parking circuit
2quick4u
Posted: July 13, 2002 at 12:04 AM / IP Logged
whats up every body well i wanted to know were can i find the parking circuit for my 2000 neon, because i bought some lights for the car and it says splice into the parking or headlight circuit hollar back
Peace
Thug luv
mobiletoys2002
Gold - Posts: 1,050
Posted: July 13, 2002 at 12:40 AM / IP Logged
ok your parking light wire is a positive(+) black with yellow at the steering colum, your headlamp wire is violet whitealso in the sterriong column this is where the wire's are inside the car. If you want to get it outside in the engine bay to trigger a relay then you will need to go to the parking light and check with a test light or dmm for the wire.this wire in either place should show 12 volts (+) when the parking light switch is on .
Friday, August 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
