1988 Jaguar XJ6 Wiring Diagram
spaguy
Posted: October 21, 2003 at 2:22 AM / IP Logged
Hello,
I would like to know if anybody has the wiring diagram for the 88 XJ6 to install a 2-way FM-2009 Alarm system.
Thanks,
Z32tt
Member - Posts: 17
Posted: October 28, 2003 at 11:47 PM / IP Logged
|              12V|brown               |+  |right dash fusebox          |
|          STARTER|white *1            |+  |relay #4, 10 ga *2          |
|         IGNITION|WHITE/ pink *1       |+  |relay #2, 18 ga *2          |
|  SECOND IGNITION|                    |   |                            |
|        ACCESSORY|GREEN/ red           |+  |relay #1                    |
|       POWER LOCK|PURPLE / brown        |-  |lock module *2              |
|     POWER UNLOCK|yellow/orange       |-  |lock module *2              |
| PARKING LIGHTS +|isolated by modules |   |better to use negative      |
| PARKING LIGHTS -|blue/green          |   |relay #3, small guage       |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|RED / lt. green       |-  |CPU behind relays C13       |
|  TRUNK/HATCH PIN|RED / yellow    *3    |-  |C18 at plug by column       |
|       TACHOMETER|WHITE/ black         |   |at coil                     |
|       BRAKE WIRE|purple              |+  |brake pedal switch          |
|     HORN TRIGGER|                    |   |                            |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|org/blue, org/black |   |Each door has relays        |
|  RF WINDOW UP/DN|same                |   |built into switch. Run      |
|  LR WINDOW UP/DN|same                |   |wires in each door to       |
|  RR WINDOW UP/DN|same                |   |motor. Rest at ground.      |
Notes:
*1 This vehicle uses grounds at the ignition switch to turn on relays and modules. To interface with the negative ignition wire to remote start, see directfax document #1500 for wiring information. This vehicle uses low-current, low-voltage switching in many places in the electrical system. Test wiring with a digital VOM. Do not use a test light.  *2 Relays located below right side dash. Remove panel to access. Lock module mounted vertically to right of relays. Small black plastic box.  *3 Diode-isolate dash end of wire. Sits at ground with ignition off.
