panic button for neon on/off switch
312eclipse
Member - Posts: 6
Posted: November 13, 2003 at 8:22 PM / IP Logged
I need some help. For my term project in an intro to electronics course I want to use my existing panic button on my OEM keyless entry remote to turn some underbody neons on for my 1999 Eclipse. The problem Im running across is not being able to find any wiring diagrams for how my panic button is wired. If looke at the diagrams here and my repair manual and nothing. Some help in this department would be much appreciated.
I want to disconnect the flashing lights and horn from the relay this panic button goes to and instead make it turn on/off some neon lights.
I hope to hear from several of my fellow 12V enthuasists.
GERARDO
auex
Platinum - Posts: 5,041
Posted: November 13, 2003 at 9:11 PM / IP Logged
The problem is that the panic button isn't wired at all, that is when you push the button on the remote there is no wire that tells the car you pushed it, it runs through the car's computer. When you hit the panic button the car's computer sends out the pulses to the lights and to the horn.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
312eclipse
Member - Posts: 6
Posted: November 13, 2003 at 9:27 PM / IP Logged
what would be a good way to go about doing this project then?
auex
Posted: November 14, 2003 at 7:22 AM / IP Logged
Are you asking for yourself or for the class project?
312eclipse
Member - Posts: 6
Posted: November 14, 2003 at 11:13 AM / IP Logged
Im asking for myself and for my class project, because I turned in my class proposal stating that this is what I intended to do to my car. Is there any way of making a remote? Or buying something enexpensive to do what I need it to do? Thank you for your time by the way
auex
Posted: November 14, 2003 at 1:30 PM / IP Logged
Well you could buy the cheapest keyless entry module that has an output and you could tie it into that. The reason that I asked about the class part is if you need to come up with something on your own to integrate it or if you could just buy another module to use. If you buy a keyless entry system it will be really easy, especially if all you hook up is the neon's to the module.
312eclipse
Member - Posts: 6
Posted: November 14, 2003 at 10:46 PM / IP Logged
once again thank you... I might end up having to do just that. Is it pretty easy to wire a keyless entry?
genehewett
Copper - Posts: 151
Posted: December 13, 2003 at 6:46 PM / IP Logged
you can do this with a device that  periphrel electronics makes called a pulse timer but it dose much more. you wont be able to use the panic button but you could use lock or unlock. on this product there are many ways to program the inputs and outputs so you would be able to program one of the inputs to make a latched output when it gets say 3 pulses or however many you want to use and also cut off the same way. good luck.
