2002 Dodge Caravan Wiring Diagram
Welcome Guest :)
dan768
Copper -
Posted: July 24, 2002 at 11:15 PM / IP Logged
All I got is this,let me know how it goes.
Year(s): 01-02 | Make(s): Dodge/Chrysler | Model(s): Caravan | |
12 Volt (+) | 12ga. WHITE/ Red at top connector of B.C.M. |
Ignition 1 | 16ga. Pink/White at ignition harness (also leads over to BCM) |
Ignition 2 | |
Ignition 3 | |
Accessory 1 | |
Accessory 2 | |
Starter | 16ga. Yellow at same |
Horn | 16ga. GREEN/ Red (+) at horn element below left head light (head light is easily removed by undoing the three Black screws on top of the light) |
Tachometer | |
Lights (+) | 18ga. WHITE/ Dk. Brown at left head light or at driver’s kick panel |
Lights (-) | 18ga. WHITE/ Brown at BCM bottom connector @ 1500 ohm (will turn on parking and head lights) |
Brake Lights | |
Door 1 | 18ga. Violet (-) (D.D.) at center connector of BCM located against firewall left of steering column |
Door 2 | 18ga. Violet/White (-) (P.D.) at same |
Door 3 | 18ga. Violet/Gray (-) (L. Slider) at same |
Door 4 | 18ga. Violet / YELLOW (-) (R. Slider) at same |
Interior Lights | 18ga. Violet/Orange (-) (hatch trigger) |
Trunk/Hatch | 18ga. Violet/Orange (-) at center connector left half (place diode inline with cathode towards vehicle – also use for dome light supervision) |
Hood Pin | 18ga. Violet/Blue (-) at same on left side of connector |
Trunk Release | |
Lock (switch) | 18ga. Violet/Green (-) @ 5600 ohm at center connector of BCM |
Unlock (switch) | 18ga. Violet/Lt. Green (-) @ 2000 ohm (either wire will lock or unlock doors) |
Driver Unlock | |
Arm (key) | 18ga. Violet/Blue (-) @ 2000 ohm at same on right side of connector (also locks doors) |
Disarm (key) | Same wire @ 5500 ohm (also unlocks doors on second pulse) |
Arm Input | 18ga. Tan/White (M) at BCM 2nd connector from the top (requires 1k to 10k ohm resistor between vehicle and arm input to alarm) |
Disarm Input 1 | 18ga. Tan/Lt. Green (M) at same (all input wires, Lt. Green, Red, RED / Black, must be connected to ground through 10k ohm resistor’s) |
Disarm Input 2 | 18ga. Tan/Lt. Blue (M) at same |
LF Window Up | | LR Window Up: |
LF Window Dn | | LR Window Dn: |
RF Window Up | | RR Window Up: |
RF Window Dn | | RR Window Dn: |
Additional Info | The door lock switch appears to have a threshold, if the Violet/Green sees resistance near 2200 ohm it seems to be confused as to whether it should |
| lock or unlock. If you stay below 2000 ohm it will always unlock. If you stay above 2300 ohm it will always lock. The values used here are taken |
| from the EVSII Mopar factory alarm system kit used for this vehicle. |
Also see
here.
dan
Remember (there are no hard cars,some just take longer to install on then others)
dflanary
Member -
Posted: July 25, 2002 at 8:09 AM / IP Logged
Dan,
Thanks, I'll give it a try and let you know how it matches the vehicle.
Dennis
Tuesday, July 15, 2025
• Copyright © 1999-2025 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
