1990 Mustang Door Pins
foder
Member - Posts: 7
Posted: July 24, 2002 at 9:22 PM / IP Logged
I have installed a Clifford XL 1000 alarm and everything works fine except for the door pin trigger. I connected the gray alarm wire to the BLACK/ blue door pin wire (per the bulldog wire diagram). If i release the pin, nothing happens. If I then depress the pin, the alarm will trigger. Any ideas?
Erick
go2pac
Copper - Posts: 179
Posted: July 24, 2002 at 10:06 PM / IP Logged
Did you program for postive door trigger? Default is negative.
Karl
Pacific Accessory Corporation
Mobile Audio Interfacing Equipment
Connecting You to Your Music Since 1976
foder
Member - Posts: 7
Posted: July 24, 2002 at 10:25 PM / IP Logged
The alarm is a self-programming door trigger polarity type.
Erick
dan768
Copper - Posts: 49
Posted: July 24, 2002 at 10:38 PM / IP Logged
Are you using these wires?
Door 1
18ga. BLACK/ Blue (+) or Gray at driver’s kick panel
Door 2
Door 3
Door 4
Interior Lights
Same as door trigger
dan
Remember (there are no hard cars,some just take longer to install on then others)
Monday, July 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
