02 dodge ram alarm/remote start
ketelle
Posted: January 19, 2004 at 1:04 AM / IP Logged
wiring schematics for 02 dodge ram 1500 5.9 for a remote start alarm dome light wire,door pin wire,horn honk{best spot},power window wires. Every other helpful wire please. Thank You
boomer_106
Silver - Posts: 710
Posted: January 19, 2004 at 11:07 AM / IP Logged
Dodge
Ram Pickup
2002-2004
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS
Ignition #1:
BLUE (16 AWG)
Ignition #2:
RED
Ignition #3:
GREEN & ORANGE (2 WIRES)
Accessory:
BLACK/ WHITE & BLUE (2 WIRES)
Brake Light:
WHITE/ TAN
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
TAN/RED
AT IGNITION COIL
Parking Lights:
PURPLE / YELLOW
HEADLIGHT SWITCH*
Headlights:
PURPLE / YELLOW
HEADLIGHT SWITCH *
OEM Alarm Disarm:
LT. GREEN/ ORANGE *****
HARNESS COMING IN FROM DRIVER'S DOOR
OEM Alarm Arm:
Diesel Glow Plug:
ORANGE / Black
Powertrain Control Module***
Clutch Bypass Wire:
Notes:
* This Is A Single Wire System. Parking Lights Need To See A Ground (-) Through A 330 Ohm Resistor. Headlights Need To See A Ground (-) Through A 700 Ohm Resistor. ** Diesel Vehicles - ORANGE / Black Wait to Start; Tach Wire Is Gray/Black. Both Wires Are Located In A Black Connector Center Top Of Fire Wall. There Are Two Black Connectors, The Correct One Does Not Have A White Insert. *** Tach can also be located at pin 74 behind instrument cluster.
Dodge
Ram Pickup
2002-2004
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
PINK/BLACK
Starter Kill:
YELLOW
Ignition +12 Volts:
BLUE (16 AWG)
Dome Lights/Superv:
SEE NOTE ***
OEM Horn:
BLACK/ RED (-)
STEERING COLUMN HARNESS
Power Lock:
WHITE/ GREEN
DRIVER'S KICK PANEL ****
Power Unlock:
WHITE/ GREEN
Trunk Release:
N/A
Alarm Input Wire:
SEE NOTE ***
Notes:
*** Separate Triggers For Each Door. The Driver's Door Trigger Is Tan (-). The Left Rear Door Trigger Is Tan/Orange (-). Both Wires Can Be Found In The Driver's Kick Panel. The Passenger Front Door Trigger Is Tan/Red (-) And the Passenger Rear Door Trigger Is Tan / YELLOW (-). Both Of These Wires Can Be Found In The Passenger Kick Panel. Diode Isolate Each Wire For Alarm Trigger With The Bands Facing Away From The Alarm/Remote Start Module. Use Only One Trigger For Dome Light Supervision. **** Single Wire Door Lock System See Note #211. Lock Requires A Ground (-) Pulse Through A 867 Ohm Resistor. Unlock Requires A Ground (-) Pulse Through A 364 Ohm Resistor. Diode Isolate One Of The Wires. ***** Requires A Negative Pulse Through A 1.5 K-Ohm Resistor.
