nissan quest '96 remote starter problem
UncleJohnzy
Member - Posts: 16
Posted: January 29, 2004 at 11:11 PM / IP Logged
Hi everyone!
I need help if someone can spot out the problem here,.  .. on the nissan quest '96, I install a commando 5005 not long ago, everything seems to work fine 'til recently, .... the car won;t start with either the remote or KEY... So I thought it 's the starter moter went bad, have it check out and is noting wrong,,,,, So I remove the unit and it still won't start with the KEY,,,, then I cut up almost all wires,,, then it started ok with the KEY,,,, any idea,,,, Helps are appreciated...
bmf1000d
Silver - Posts: 345
Posted: January 29, 2004 at 11:26 PM / IP Logged
did ya check all your wiring for the car?
when you say cut most of the wires you mean the wires from the RS?
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
UncleJohnzy
Member - Posts: 16
Posted: January 29, 2004 at 11:29 PM / IP Logged
didn't check them wires yet, and yes, cut some wires from the rs
bmf1000d
Silver - Posts: 345
Posted: January 29, 2004 at 11:34 PM / IP Logged
like the ignition wires? if you you may have to diode isolate them. here is the diagram that i have
NISSAN QUEST 1996-98
WIRE COLORSLOCATION
12 VOLTS CONSTANTWHT/PUR IGN HARNESS
IGNITION 1       BRNIGN HARNESS
IGNITION 2  N/AIGN HARNESS
IGNITION 3IGN HARNESS
ACCESSORY /HEATER BLOWER 1WHT/GRNIGN HARNESS
ACCESSORY /HEATER BLOWER 2
STARTERRED & RED / GRNIGN HARNESS
PARKING LIGHTSORG/BLKAT HEADLIGHT SWITCH
DOMELIGHTBLUAT SMART ENTRY CON TIMER
PWR DOOR LOCKGRN/ORG16 PIN CONN HIGH IN DR KICK
PWR DOOR UNLOCKGRN/WHT16 PIN CONN HIGH IN DR KICK (TYPE B)
TRUNK RELEASE
TACH SENSORGRN/WHTPIN 3 ON ENG CONT MOD
BRAKE
YEL/BLKAT SWITCH ABOVE BRAKE PEDAL
HORN
  YEL (-)STEERING COLM
FACTORY DISARM
  RED / BLKDRV KICK PANEL
"Big" Mike
Double Take
Fremont, Ne
UncleJohnzy
Member - Posts: 16
Posted: January 29, 2004 at 11:39 PM / IP Logged
What do you mean by diode them?
bmf1000d
Silver - Posts: 345
Posted: January 29, 2004 at 11:42 PM / IP Logged
diode isolate means to put and isolator in the way for the current...kinda like a 1 way valve so that it does not back feed to the RS or car. I had to do this on a 04 town and country cause it keep sending 300ma to the start wire and woudl nto RS. here is the link for ya
https://www.the12volt.com/diodes/diodes.asp
"Big" Mike
Double Take
Fremont, Ne
UncleJohnzy
Member - Posts: 16
Posted: January 29, 2004 at 11:48 PM / IP Logged
I know what you mean now and no i didn't install with diode... and  could the diode solve the problem with unable to start... I mean it work fine before that
thanx
UncleJohnzy
Member - Posts: 16
Posted: January 30, 2004 at 12:46 AM / IP Logged
bmf1000d,,,, any other input??? anyone?
jrilla
Gold - Posts: 1,498
Posted: January 30, 2004 at 9:08 AM / IP Logged
Did you have a starter kill relay installed?
J Rilla
Owner/Installer
