Damping - matter of opinion
bryceyaworsky
Copper - Posts: 152
Posted: April 01, 2004 at 10:07 PM / IP Logged
I've seen doors that have damping material covering the whole thing, others that cover only the inner-metal frame on the door (not the holes), and others which cover the inner and outer metal frame of the door.
Which do you prefer when doing an install, and for what reasons?  Do you cover the entire surface of the car (including empty spaces), or do you just apply damping material to the metal?  Why?
defective
Silver - Posts: 642
Posted: April 02, 2004 at 11:04 AM / IP Logged
personally i prefer covering just the metal..... air between the holes doesn't resonate much. It is a waste of dynamat. The outer door metal is a nice touch and is recommended but you must pay for the xtra dynamat to do that surface as well. The main reasons for dynamating the whole inner door skin (including holes) is either laziness (you dont have to cut out all the xtra), or a false sense of secuity that you doors are acting like a sealed enclosure, no matter how much dynamat you use, they will NOT be sealed.  Also trying to seal ytour door with dynamat is useless becasue it will flex anyway, kinda like a baffle box.... So in conclusion, deaden the metal, as much of the metal as you can reasonably afford. All that wasted mat on deadening the air :) you can use on other peices of meal, a little dynamat on each of the keys in you keychain can silence them....only an installer : )
tricken
Posted: April 02, 2004 at 6:27 PM / IP Logged
plz dont cover the whole door 1st reason it shows u r ver very lazy 2nd it makes it hard to replace window motors lube cranks and get to door lock and other pieces in the door.
89 xp b20a aws 3rd gen prelude
mobile1
Silver - Posts: 479
Posted: April 03, 2004 at 12:46 AM / IP Logged
100% agreed. If you are going to do a job, do it right. Don't be lazy
bryceyaworsky
Copper - Posts: 152
Posted: April 03, 2004 at 2:53 AM / IP Logged
I seem to have given the impression that I'm planning to do the whole door/ metal surface, and this is not so.  I was just trying to get some insight as to why you do it the way you do (however that may be).  I've seen a huge variation in how damping material's applied, and it's given me some curiosity in regards to the benefits of each method.  Anyone from the other side of the fence care to comment?  It'd also be nice to hear from someone who does cover the entire surface.
defective
Silver - Posts: 642
Posted: April 05, 2004 at 10:01 AM / IP Logged
the people who cover the whole thing are lazy and uneducated..... I Graduated from the Dynamat Dynamic Control University...:)... ya i know its a joke.   I actually have a diploma directly from Dynamat....   Anyway, honestly you should only cover the metal....   I'm sorry i had to bring out the sad diploma but.... well education speaks for its self... (laugh)
