relay advanced?
shutout31
Posted: April 07, 2004 at 11:00 PM / IP Logged
In my last car i did the radio on until door opened configuration but now i want to do something a little different with multiple operations. I have a two din spot in my truck, 1 din being used up by an aftermarket radio. I want to make a fake plate that looks exactly like the stcok radio that will cover the radio for security and just for experimental/learning purposes. Here's the complicated part, a motor with gears will push the fake cover out from above the hu and then it will flip down at a joint. i want this to be triggered by the door opening (door trigger wire) with the ignition in the off position. then when the ignition/accesory wire gets power i want the motor electricity (neg and pos) to be reveresed so it will pull the bezel back to the original spot. i am going to have to incoorporate a time switch or something also so any help or ideas about that would be great. but basically the question is how can i wire this up? how many relays? what types (single throw, double throw, etc)? this seems pretty complicated but i think it can be done, thanks in advance to whoever tries to help me out, it's appreicated.
- Scott
shutout31
Posted: April 08, 2004 at 6:36 PM / IP Logged
please anyone? i imagine i'll need about 6 or 7 relays and some diodes but i could really use some help. thanks.
- Scott
shutout31
Posted: April 09, 2004 at 6:00 PM / IP Logged
could anyone give me a general idea of how this would work or if it would work at all? thanks.
- Scott
shutout31
Posted: April 13, 2004 at 12:47 PM / IP Logged
xetmes
Silver - Posts: 586
Posted: April 13, 2004 at 5:16 PM / IP Logged
haha well you are persistant...
Its really hard to tell what you will need to do, make a table to tell exactly what you want to do...
ie:
door opens -> motor energizes -> turns off when panel has reached maximum
the biggest problem may be when to kill power to the motor, or whatever you are using to move it..
