Dome Light Wire - Dakota
Peedee
Member - Posts: 12
Posted: April 07, 2004 at 11:55 PM / IP Logged
Hi, I have a 2002 Dodge Dakota and need to know which wires from the multi-function light switch are for the dome light and cargo light. I am installing the factory bed light/power outlet but it is for a 2000, so I am concerned that the wire color may have changed. I am going on a trip this weekend and don't want to take any chances of ruining something. Please help.
jfk51502003
Copper - Posts: 221
Posted: April 08, 2004 at 5:09 PM / IP Logged
12volts pnk/blk & RED / lt blu   +  ignition harness
Ignition blue   +  ignition harness
Parking Lights+ BLACK / YELLOW    headlight switch
Parking Lights- RED / yellow    conn. 1, pin 4 @ CTM
Notes: The Central Timer Module is in the driver kick panel.
Headlight lt. GREEN/ orange   -  headlight switch
Trunk/Hatch Release
Power Sliding Door
Speed Sense WHITE/ orange or blue    conn. 2, pin 27 @ PCM
Notes: The Powertrain Control Module is on the passenger fender.
Wipers purple(L), RED / gry(H   +  steering column
LF Window up/dn lt. blue - white   A  driver window switch
RF Window up/dn brn/wht - pur/wht   A  driver kick panel
LR Window up/dn blu/wht - RED / blk   A  driver kick panel
RR Window up/dn gry/blk - grn/wht   A  driver kick panel
Sun Roof open/close
Sun Roof Limit/close
Memory Seat 1
Memory Seat 2
Memory Seat 3
Dome Light Wire - Dakota - Last Post -- posted image.
Immobilizer Bypass Module:Required: YesType: Sentry KeyPart #: 555C or 555U
Notes: Only vehicles with gray keys have the immobilizer.
jfk51502003
Copper - Posts: 221
Posted: April 08, 2004 at 5:10 PM / IP Logged
Starter yellow   +  ignition harness
Second Starter
Second Ignition GREEN/ red (18 ga)   +  ignition harness
Third Ignition
Accessory BLACK/ orange   +  ignition harness
Second Accessory green   +  ignition harness
Keysense
Power Lock WHITE/ green  -  conn. 2, pin 10 @ CTM
Notes: Lock is negative trigger thru a 820 ohm resistor. Unlock is negative trigger thru a 330 ohm resistor. MUST use relays.
Power Unlock same wire
Lock Motor ORANGE / black    conn. 2, pin 4 @ CTM
Unlock Motor blue (4 dr only)    conn. 2, pin 6 @ CTM
Notes: The 2 door models do not have progressive unlock on the factory keyless.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger    -  CTM
The driver door trigger is tan in connector 2, pin 15. The passenger door trigger (and rears on the 4dr) is tan/red in connector 2, pin 13. Use both and diode isolate each. See directfax document #1076 for wiring information.
Dome Supervision use door trigger
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm lt. GREEN/ orange  -  conn. 2, pin 14 @ CTM
Notes: Arm is negative trigger thru a 644 ohm resistor. Disarm is negative trigger thru a 1565 ohm resistor. MUST use relays. This wire will also lock the doors, and it will unlock with a double pulse.
Factory Alarm Disarm same wire
Disarm No Unlock
Tachometer     ignition coil
Notes: On the 2.5L/3.9L/5.9L models use BLACK/ gray at the ignition coil. The 4.7L models have an ignition coil for each cylinder, use the wires that is NOT GREEN/ orange at one of the coils.
Wait to start
Brake Wire WHITE/ tan   +  brake pedal switch
Parking Brake
Horn Trigger BLACK/ red   -  steering column or CTM
Memory Seat 1
Memory Seat 2
Memory Seat 3
Peedee
Member - Posts: 12
Posted: April 09, 2004 at 6:26 AM / IP Logged
thanks jfk for posting the chart. The problem I have now is that the info refers to "The driver door trigger is tan in connector 2, pin 15. The passenger door trigger (and rears on the 4dr) is tan/red in connector 2, pin 13. Use both and diode isolate each. See directfax document #1076 for wiring information." I went to the directech site but can't get in w/o pswd, so I am not sure what is required.
Just in case this is not really what I need to do, I will reiterate. I want the bed light to come on when I use the factory unlock, which makes the dome lights come on. I also want to be able to use the dash switch to put it on. The instructions that came with the light refer to the white wire from the light switch, but it is for a 2000 and mine is a 2002. The white from the switch does not work. I found the ( - ) going to the dome light and spliced in there, but now after I shut down and close the door the radio has power to it and if the radio is off, the clock is on. the factory light has 3 wires, one ground, one power one to connect to the ( - ) for the dome lights. The power is spliced to both the light and power outlet at the fixture. Any help would be appreciated. This has taken way too much time already.
Peedee
Member - Posts: 12
Posted: April 09, 2004 at 4:19 PM / IP Logged
thanks for the help, The wire I needed was the yellow with red stripe on the center connector of the timer module. That is the cargo light ( - ) switch wire. I called the forman at the dealer just to make sure I didn't ruin anything.
