proxy with window mods
mobile1
Silver - Posts: 479
Posted: April 14, 2004 at 9:07 PM / IP Logged
 I have a 99 explorer with a clifford rs3.5x. I was wondering if i get window mods and a proxy sensor is there any way i could get the warn away sensor from the proxy to trigger the window mods without setting off the siren, and the full trigger on the proxy to set off the alarm? I saw a post in here that had a diagram for the proxy to set off the window mods, but that would also trigger the siren. I've been racking my brain on this one, so I figured I throw it out there for all of you.
mobile1
Silver - Posts: 479
Posted: April 14, 2004 at 9:08 PM / IP Logged
I forgot to mention the window mods and proxy are all dei as well. Just in case
defective
Silver - Posts: 642
Posted: April 15, 2004 at 9:12 AM / IP Logged
again i'm not a mod, but try asking in the security threads, you will get a faster answer... were all up to our neck in MDF dust and body filler around here.proxy with window mods - Last Post -- posted image.
robbie2883
Copper - Posts: 104
Posted: April 15, 2004 at 10:49 AM / IP Logged
the proxy  sensor should have two negative outputs. one for warn away and the other for full alarm. hook the warn away output of the sensor to the ground input on the window modules.  the full alarm output needs to go to a ground input trigger on the alarm. you know, a door trigger or something. and there ya go
if its jammed force it - if it breaks in the process it needed to be fixed anyway
