wireless fm modulator noise
timkim6890
Posted: May 14, 2004 at 3:34 PM / IP Logged
  I just installed an xo vision wireless modulatior in my 2004 Tahoe and I am getting mostly static on my car stereo system. The stereo is OEM . My question is will a ground loop isolator solve this problem or is there something else I need for this.  Thanks in advance
auex
Platinum - Posts: 5,041
Posted: May 14, 2004 at 10:20 PM / IP Logged
It would probably help, but any fm mod is notorious for static and engine noise. You should definately look into what is called as "auxilary input adapter". This will plug into the cd changer control port on the back of the factory radio and will feed the audio signal directly to the radio.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
rudbwoy69camaro
Silver - Posts: 350
Posted: May 15, 2004 at 12:14 PM / IP Logged
forget the ground loop isolator-they do the job not what you want.  auex is right.  I have an '02 tahoe and bought the PAC "Auxiliary Audio Input Interface."  even my father-in-law notices the difference when we play dvds in the truck now.
Franco90
Copper - Posts: 48
Posted: May 15, 2004 at 1:23 PM / IP Logged
Where can I buy one for JVC radio (auxilary input adapter) can any one help me with link i have same problem as timkim6890.
rabenoja
Copper - Posts: 61
Posted: May 18, 2004 at 10:05 PM / IP Logged
I've been using wireless fm mods for a few months now, without any problems.  I was skeptical at first because of my experience with the other wireless fm mods.  I encountered the same problems that you were having.  Anyway, it seems that the unwired or icon wireless fm mods work pretty good.  There is a trick to installing them though.  I usually extend the antenna wire so that I get better/stronger reception.  I also wrap the whole fm mod in black electrical tape to make sure that the casing of the metal doesn't touch any ground.
Franco90
Copper - Posts: 48
Posted: May 19, 2004 at 9:27 PM / IP Logged
I will try that thanks again rabenoja
Wednesday, November 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
