Do I need more than 1 relay for 2 sets ?
simon_templar
Posted: May 17, 2004 at 11:11 PM / IP Logged
Will I need to install more than 1 relay, if I am using 2 sets of 55watt halogen driving lights on the front of my 1992 pontiac trans am ?
The + wires to the lights are getting real hot.
I am currently using a 30 amp relay for 2 sets of lights.
55 watt halogens draw 4.5 amps per bulb . . . so the relay should be able to handle the  18 amps required.
The present  gage of wire is # 10.
Shouldn't that size be sufficient ?!!!
S I M O N
auex
Platinum - Posts: 5,041
Posted: May 17, 2004 at 11:17 PM / IP Logged
If 10 gauge wire is getting hot then there may be another problem. How well is the ground to the lights?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
simon_templar
Posted: May 18, 2004 at 3:58 PM / IP Logged
Perfect ground to body of car. . .   (no rust or corrosion).
brendo_87
Posted: June 02, 2004 at 12:44 AM / IP Logged
how old are the wires, cause if they are old they could have to much resistance thus creating all the heat through friction
