2002 Ford F-250 Alarm/Remote Start Wiring
draasch
Gold - Posts: 2,172
Posted: May 22, 2004 at 11:18 PM / IP Logged
heys guys,
i am at the station tonight and have an install here for one of the guys atht i work with. i dont have my notes with me for that truck. can someone help me out???
thanks.....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
raydawg357
Silver - Posts: 769
Posted: May 24, 2004 at 7:59 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES SUPER DUTY / 2002 / Remote Start
[PRINT THIS PAGE]
12volts yellow & lt. grn/pur   +  ignition harness
Starter green   +  ignition harness
Second Starter
Ignition RED / lt. green   +  ignition harness
Second Ignition
Third Ignition
Accessory gry/yel & RED / blk   +  ignition harness
Second Accessory blue/lt. green   +  ignition harness
Keysense
Power Lock
Notes: Without keyless entry use pink / YELLOW for lock and pink/lt. green for unlock. They are 5 wire reverse polarity mastered from the driver switch and found in either kick panel. With keyless entry use WHITE/ red for lock and BLACK/ white for unlock. They are negative trigger and found at the VSM. On the vehicles with keyless entry the GEM shuts down after the doors have been locked for a certain time period, to wake-up the system refer to directfax document #1094.
Power Unlock
Lock Motor pink/black    VSM
Notes: The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Unlock Motor RED / orange    VSM
Parking Lights+ brown    headlight switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger BLACK/ lt. blue   +  either kick panel
Dome Supervision use door trigger
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer     ignition coils
Notes: For tach go to any one of the ignition coils and use the wire that is NOT RED / lt. green. On diesel vehicles the tach wire is green or white, in a 42 pin plug under the clamp on the engine side of the air intake duct. On diesel vehicles the wait to start light is activated by a databus wire from the ECM. To do wait to start use a pulse timer relay and follow directfax document #1091.
Wait to start see DirectFax document 1091
Brake Wire lt. green   +  brake pedal switch
Parking Brake
Horn Trigger blue   -  steering column or VSM
Memory Seat 1
Memory Seat 2
Memory Seat 3
2002 Ford F-250 Alarm/Remote Start Wiring - Last Post -- posted image.
Immobilizer Bypass Module:Required: NoType: N/APart #: N/A
Notes: N/A
Do it right the first time
draasch
Gold - Posts: 2,172
Posted: May 24, 2004 at 8:02 AM / IP Logged
thanks for the info...
Good Luck
David
Ace Security
813-376-9778
Tampa
