Chrysler 300 2005 remote starter
franK111
Posted: June 15, 2004 at 8:21 AM / IP Logged
Looks like the second starter wire on this car is also a second ingnition like the pacifica.Is anybody as the correct resistor value and/or diag. for this car.
With only the second starter activated with a 180ohms resistor the car will start but the instument cluster (fuel gage etc) won`t come on and  this sends a fault signal to the ECM and the check engine light come on .
hawkinstaller02
Member - Posts: 44
Posted: June 15, 2004 at 11:36 AM / IP Logged
I think the dei tech sheet only shows 2 ing wires, there are 3.
the 3rd ing is the same color i think as the 2nd but much bigger gauge. Pink / YELLOW
when you meter it, it will NOT read like a true ing, just reads voltage for a sec or so, but it needs to be energized to work. only voltage during run, not crank, but not acc either.
I think that might help, one of our other installer had hell with a 05 durango, 14 hours, he had the same type of problems engine light
Did that work???????
-Installer-
audioconnection
Member - Posts: 45
Posted: June 15, 2004 at 11:53 AM / IP Logged
I used the third ign output to the purple with blue i think it was . the wire that changes voltage as you turn the key from 4 down to 2 volts.
and have not had any problems
remember...Friends Dont let friends Install, Take it to a pro..
audioconnection
Member - Posts: 45
Posted: June 15, 2004 at 11:54 AM / IP Logged
email me if you need the whole sheet for this car.
BTW do not test the white and WHITE/ orange wires going through the car
these are can bus.
franK111
Posted: June 15, 2004 at 12:04 PM / IP Logged
Yes please e-mail the complete sheet i will compare it with mine
franK111
Posted: June 15, 2004 at 12:05 PM / IP Logged
Here i my e-mail:
f.egee@b2b2c.ca
derek123
Copper - Posts: 163
Posted: June 15, 2004 at 12:50 PM / IP Logged
Wire the "magic wire" as 2nd Ign (-) and use a 500 ohm resistor.
This is close enough to the crank value, AND close enough to the run value, to let it start ( and run) without setting a code.
You want to disarm the OEM alarm, on that same wire too ?
erasing codes is easy on this one. just disconnect the Negative battery post ( pass. trunk) and try and key start the car. plug the battery back in.  code gone.
Our first one took 2 of us most of a day, with a chrysler diagram of the Ign switch.
jcap
Member - Posts: 41
Posted: June 15, 2004 at 11:22 PM / IP Logged
note; if you hooked up ignition wires as per (wiremagic) . the cruise control on the vec will not work!
jcap
johnmax
Copper - Posts: 131
Posted: June 16, 2004 at 5:32 PM / IP Logged
Can anyone post the tech info for us non DEI tech info havin folks?Chrysler 300 2005 remote starter - Last Post -- posted image.
Sunday, July 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
