Remote start not remote starting!?
fugit
Copper - Posts: 169
Posted: July 09, 2004 at 9:04 AM / IP Logged
I'll try this again.  I installed my viper 560xv on my 96 yukon and everything works great except for the RS.  I posted up before, https://www.the12volt.com/installbay/forum_posts.asp?tid=33109&KW=yukon+remote+start but never really got anywhere so I'll try again.  I don't have the neutral safety switch, hood pin, or brake wires connected.  ( I got sick of messing with them)  Any help will be appreciated.
"I'm Rick James bi***, enjoy yo' self Ah Ah Ah"
Dave Chappelle as Rick James
profuse007
Gold - Posts: 2,015
Posted: July 09, 2004 at 12:26 PM / IP Logged
neutral safety switch- ground it
hood pin- use the pin provided by viper
brake- need to hook it up to to brake switch(+)
Houston,TX
fugit
Copper - Posts: 169
Posted: July 09, 2004 at 4:38 PM / IP Logged
I had the neutral safety grounded and the brake switch hooked up but not the hood switch and it does nothing.  wouldn't the hood switch only be triggered if the wire was powered, (when the hood opens and the metal of the pin touch each other) or am I backwards?
swamprat323
Gold - Posts: 1,335
Posted: July 09, 2004 at 5:22 PM / IP Logged
You dont need the hood pin, but need te neutral safty switch. the brake wire is used after u put your key in so it turns off the rs, well as long as you key is in the on posistion.
But should hook up the hood pin, for safty reason say you are working on your car. plus your hood is also armed. the netural switch is also for safty reason, its your car so you do what u want.
fugit
Copper - Posts: 169
Posted: July 09, 2004 at 5:40 PM / IP Logged
The only reason I didn't connect them is because I couldn't get the RS to work. I'd like to connect EVERYTHING.  It will crank up if I ground the trigger wire from the relay, but it won't do anything with the remote(s).
jfk51502003
Copper - Posts: 221
Posted: July 10, 2004 at 1:25 PM / IP Logged
what combination on the remotes are you using to remote start...?does anything happen when you try to remote start...lights flash...? remotes work alarm right...?
fugit
Copper - Posts: 169
Posted: July 10, 2004 at 1:34 PM / IP Logged
The alarm is fine, the first time I tried the remote start the lights came on and it cranked for a split second then nothing and all guage lights went off.  Now when I press the RS button I get nothing.  Remotes work alarm perfect.
Wednesday, July 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
