the wifey want a tv in the new chrysler
xavierny25
Member - Posts: 24
Posted: August 05, 2004 at 8:21 PM / IP Logged
            hi guys and thanxs for checking this out.i have the new chrysler 300 and i did my first upgrade last week which was adding soom bass to it .i put in a 10 in rockford fosgate sub and and a amp it sounds great.and thanx to u guys it happened.well here is the next project i just bought a pioneer avd-w6010 6.5 wide screen and play station 2 and i want to add this on to my car .all i want is to be able to play movies or games and get the sound from my car stereo.i now ill be needing alot of help with this install.so where do u think i should start.what i do know for a fact is that i need a fm modulator to start.from there on im lost. im good when it comes to amps and radios and subs but this video car stuff im not sure off .
        thanx xavierny25@msn.com
switch_hitter
Copper - Posts: 151
Posted: August 05, 2004 at 8:45 PM / IP Logged
now you just need a power inverter to change 110v to 12v on the ps2, run the audio cables from the PS2 to the FM MOD, and the Video Cable to the TV.......
xavierny25
Member - Posts: 24
Posted: August 05, 2004 at 9:35 PM / IP Logged
                      o0o sorry got that also how does the wiring for a fm modular work or look like any way i never had to install one so i dont now how to pick one or install one for that matter.
switch_hitter
Copper - Posts: 151
Posted: August 05, 2004 at 10:09 PM / IP Logged
An FM modulator has a 12v wire ground wire , audio inputs, and a switch to set the fm frequency, and an antenna input and output.  If i remember right its 88.3, and 89.1, but anyhow, its pretty simple to install you give it power and ground, hook up the audio jacks to it, and plug your vehicles antenna into the input and put the out put into the back of your radio......I would recommend that you get a high quality fm mod. I use Farenheit.
xavierny25
Member - Posts: 24
Posted: August 05, 2004 at 10:19 PM / IP Logged
             do they have a web site so i can check one out i really dont want to go with any thing cheap or half ass on this car.or does pioneer carry one?
switch_hitter
Copper - Posts: 151
Posted: August 05, 2004 at 10:33 PM / IP Logged
http://www.pioneerelectronics.com/pna/product/detail/0,,2076_4023_36266,00.html
check out that link, this one comes with an TV Tuner so you can pick up local stations....its expensive but you get what you pay for.
Wednesday, November 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
